Casting Work - 2025:
The game plan for 2025 is to cast some permanent aluminum patterns for a 1/2 size Baker Ball Hopper Monitor engine.
I need to 3D print the pattern halves, and coreboxes for the water hopper, which is the first part I will start with.
I have been working on how to design the hopper 3D prints and coreboxes, and I think I have that pretty much worked out.
I am going to use pattern halves, since that will make molding much easier.
I would like to cast permanent aluminum patterns, and I would like to do that indoors.
I remembered that my nextdoor neighbor has a small kiln, so I went over there yesterday and told her I needed to "requisition" it; it was a matter of extreme hobby emergency.
Casting things indoors is a good way to die, and burn your house down all at the same time.
I guess I will spread out a welding blanket inside my office, and make a catch box of sorts to pour over.
And I will put fire extinguishers all around.
Aluminum does not concern me that much as long as I can fully contain the spill from an entire crucible.
I have some crucibles smaller than a #10, and I hope to be able to use those for indoors pours.
Here is my neighbor's kiln that I will "borrow/keep".
If I drilled a hole through the lid in the center, and elevated the crucible up on a plinth, then I could take temperature readings using the pyrometer, without opening the furnace.
The $100 dollar question is "Will the thin mold half fill completely with aluminum?".
The $200 dollar question is "Will the thin complete hopper mold will with gray iron ?".
These are bridges what we will have to cross when we arrive at that destination.
Here are some of the smaller crucibles that I will try to use.
I need to calculate how much aluminum half a water hopper pattern will require, and I can do that in Solidworks.
I need to make some lifting tongs and pouring shank for these.
I may be able to make an adjustable tong and shank to fit several of the smaller crucible sizes.
By melting and pouring inside my office, I can work while the melt is heating, and keep an eye on things.
I am not sure what the wife will say, but I can probably bribe her to ok it.
The dimensions and capacities of these crucibles is as follows:
A0.5 Top: 2.625", Bottom: 1.875", Height: 3.125", Brass: 2.2 lbs, Cast Iron: 1.98 lbs., Aluminum: 0.7 lbs.
A3 Top: 4.125", Bottom: 2.75", Height: 5.0", Brass: 8.2 lbs, Cast Iron: 7.38 lbs, Aluminum: 2.7 lbs.
A5 Top: 4.875", Bottom: 3.375", Height: 6.0", Brass: 15 lbs, Cast Iron: 13.5 lbs, Aluminum: 4.9 lbs.
Note that the number following the "A" is the approximate crucible capacity for aluminum, in pounds.
