- Dec 31, 2010
- 820
- 220
John:
Can you check "Detail A" the assembly of the carburetor pieces On the assembly drawing sheet.
You show the end of the air intake tube with the narrow ridge inserting into the carb body.
The recess in the body to accept the tube is 0.2" deep. The ridge you show inserted is only .093 wide
The other end of the air tube has the 0.2" wide ridge which would be matched to the body recess.
BUT
Turning the tube around would move the Needle valve farther from the carb body.
I'm not sure what the correct orientation should be.
BTW. Fantastic and very professional drawings.
Thanks
BUT
Thanks
