- Feb 18, 2013
- 453
- 294
Well, the engine is complete but alas no sounds of life at all :-(
I tried flicking, RKlopps method with a rubber tube on the spinner which is much easier but still not a pop.
I even resorted to using a starter but coupled with rubber tubing which slips if hydraulic lock occurs. This gave a slight crackle at speed but nothing substantial.
The fuel I have is way old but stored in a good sealed container but I wanted to eliminate the fuel so mounted the Clanford Clan on the bench and sure enough she started and ran .
I can only guess my compression is not quite up to scratch which means another piston to make as I would expect the engine to at least show some life on priming only irrespective of any other timing/carburation problems.
Compression seemed good to me for such a small motor.
So it may be while before I am back here otherwise it may be just a failure ornament!
