Atom race
kadora
Hi engine addicted
I would like to show you my Atom engine / my third engine / built from French
castings www.modelenginebuilder.com
I have built this engine one month because it is easy going kit.
I want to run engine on propane-butane gas but I have to learn
how to feed engine with gas . /YOUR HELP IS WELCOME /
This engine is probably my last single cylinder i would like to build
V twin now /is possible to buy casings for V twin somewhere ?/
Thank you
Best wishes from Slovakia.
Very nice build, where did you buy those castings?? Do you have a link?
Thank you
Try Google Translate. I did and this:
Diamètre de la turbine (élément rotatif) : 40.2mm
nombres de pales: 24
angle d'attaque du jet de vapeur: 20° (attaque tangancielle)
Profil des pales: "en banane à bord tranchant pour limiter les pertes de charges)
Diametre du carter de turbine: 50mm
type de roulement: race, Øaxe 4mm, regime max dans huile 70000tr.min
Translated to this in English:
Impeller diameter (rotatable): 40.2mm
numbers of blades: 24
angle of attack of steam: 20 ° (tangancielle attack)
Profile blades "banana sharp edge to minimize pressure losses)
Diameter of the turbine casing: 50mm
bearing type: race, Øaxe 4mm max in oil diet 70000tr.min
Not perfect, but it does come close.
Phil
Thank you for the link. You engine looks beautifull. Can you make a movie while it is running? I love running modelengines. I collect them also. I have between 5-600 motors wright now. But not very rare...
best regards from Belgium
Barry
Hello
Lawijt send us some pictures of your engine collection please.
Not runing yet but i prepare to feed engine with propane gas.
Phil
(yer not foolin' me - this sounds like a turbine...)
f
Hallo
Nice collection you must love engines like me.
Lawijt how many of engines in your collection are homemade?
Are on the bottom shelf ram engines ?
Thanks for pic Kadora
I have 4 handmade engines. But I don't build those.
I found those on ebay.
On the bottom you see the pulse jet's.
Barry
Lawijt
please send pictures of homemade engines from your collection
Have a nice day
Dear Kadora,
I will make some pic's from those , but when I have some time ok...I have to take out a lot of engines you know. They are all on glass plates & when one fall , the glass can break & than they are all falling too the bottom. Then I have a heart attack and nobody will see the pictures.
Hello Kadora,
Look what I found today on a swap meet....Only for 100$. Amazing how beautifull build. The cilinders,heads & pistons are from COX engines.
Do I need to tell that I'am very happy??
Greetz
Barry (lawijt)
It's beautiful, but how the heck does it work?
Those two-cycle cylinder assemblies require a pressurized crankcase to transfer the fuel/air mixture to the cylinders and that crankcase won't provide pressure.
Hello Lawijt
it is really cute engine but it is probably not working built only for display .
Anyway if you are happy then everything is OK.
Lawijt start to build your own engine then you will be very happy.
regards Kadora
Hello
Finally i got carburetor so i could make clip.
[ame]http://youtu.be/QrCSfAsmb2o[/ame]
