;D - Thanks Carl - you're welcome to hijack a bit
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- I'm more into the bitter (high cacao) chocolates; a bit of 80% after dinner is heaven - especially combined with a small glass if Kirsch!
George, thank you !
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- I'm in awe of the exceptional work you do; getting positive feedback on my efforts from yourself is very much appreciated indeed.
Thank you for the feedback and example Rick ;D (Great example by the way :bow
I made my bushing holes a tiny bit smaller to suit available material for the pins, but I bought a bunch of small drills today to use. I also expect to re-make a couple, and break some drills in the process :big:
Trout, thanks
- I'm not a big Kung Fu fan myself, but I can catch the drift... I am just building an engine to the best of my abilities, and learning in the process
I have no intention of making waves; a ripple on the surface would do
Now for an update... A bit late but here it comes:
Thursday evening I started on the bearing blocks. Some 8mm aluminium plate marked out to bandsaw the material for the bearing blocks out of:
Two blocks done to start with:
I want the two bearing blocks as near identical as possible, so I clamped them together with a toolmaker's clamp:
Off to the mill, and fly-cut both sides:
As there was quite a bit of excess material to remove, and I have not yet trammed my mill - which is out quite a bit, I took the opportunity to "visually" tram it in a bit better. Initially, the flycutter only cut on one side of the workpiece while passing over the blocks, so I stopped the mill after each pass, and rotated the head just a fraction so that the bottom of the spindle moved toward the side where the flycutter was cutting. Eventually, it ended up cutting most of the material facing the direction of feed, and leaving tiny scratches on the other side. Tramming near-enough for now.
Next, I squared up the bottom:
I didn't bother to clean up the top, as that will be machined to cosmetic lines; I just needed the bottom squared for marking out.
Finished off Thursday evening by doing the layout for the blocks. Not much done, but then again, I was interrupted for a period to explain Ohm's Law to a friend, so he could explain to his son for school... :
Friday evening.....
Off to the drill press, and drilled the mounting holes on the bottom of the blocks 2.5mm to thread M3. Before I started drilling, I set the drill press depth stop so the holes only goes 8mm deep:
Then I clamped both blocks together again; just using "finger feeling" to align the bottoms and the sides. This may seem crude, but the human finger is very sensitive to "height differences" between two objects, so as long as all the aligned sides feel smooth, they are pretty close in my book. Next up, center drill for the bearing (in my case the bearing bush; I decided to go with brass bushes for bearings):
Then a "Whoops - a - daisy" moment - I haven't tested how accurately my mill will move up and down on Z. The head was too low to fit the drill in:
I could test the mill's Z dovetail... Or I could just fit the 10mm collet to the nut, and insert the drill - outside of the machine:
And then fit it on the spindle - loads of side clearance available to angle it in and lock:
And a
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
to all the experienced machinists out there who are now howling in laughter at this idiot doing the obvious... It wasn't initially that obvious, and I am sure I'm not the first to encounter this minor problem. Just maybe it helps somebody other than myself look less of an idiot!
Back to work... Drilling for the bearing bush with lots of swarf flying around. Actually more than I usually allow; taking action photos could be dangerous!:
Done drilling the hole. As I wanted to press-fit bushes into the hole, I removed the drill slowly - at about the same rate of feeding it in initially - to leave a smoother finish without the need to use a reamer:
Next up, profiling the blocks. After I put the blocks in initially on an "impromptu parallel" and clamped it in the mill vise, I removed the toolmaker's clamp, and re-clamped it so that it was lying flat with the mill vise jaws. First, I just milled to the line; I just eyeballed it on the approach, but took note of the X readings on the mill dials for the Z steps:
With one side done, I once again used another toolmaker's clamp as a vise-stop:
I then flipped the bearing blocks vertically - after I de-burred them with a file while out of the vise. The clamp retaining the blocks was used to just set them horizontal in the jaws of the mill vise, and the end up against the other clamp meant I could use my prior X-readings to machine this side as well. Keeping track of Z readings would be useless though, as the "horizontal" clamp was not on center.
I then milled the rest off according to the X-settings I noted down earlier, and with Z feed to the scribed lines; this was more difficult than expected, as all the lines were now at the back of the mill! Next up, some light milling to contour the "decorative" tops of the bearing blocks to save on filing - "light milling", because I didn't have a lot of the workpiece clamped:
Next up, the sides of the blocks; once again, light milling, by eye to the scribed lines:
End of work for Friday evening - lots of finishing still needed:
Saturday's work follows...
Regards, Arnold
