spuddevans
- Feb 25, 2008
- 203
- 1
Crumbs, dont time fly by, hard to believe that it is not far off a month since my last update.
I have been working on this, but it has been a bit stop-start (more stop than start) as I have been just grabbing a bit of time where I can to work on it, so this post covers a few weeks of stop-starts.
I mounted the x-axis on the mill and it worked great, all it needed was a couple of 1-2mm thick packing pieces to go either side of the ballnut flange to fit neatly into the pocket from the old acme nut, then jsut tighten up the 2 grub screws and it was fine. Testing went exceedingly well and I am very happy with it.
That being done I replaced the X-axis back to the original manual acme nut and screw, and set about making the Y-axis stepper mounting, which is basically identical to the X-axis, so see the earlier pics for the details. Then I mounted the Y-axis stepper and mount onto the mill.
As you can see, there was a slight design flaw in that the gib screws of the x-axis would crash into the stepper mount, therefore limiting the x-axis by about 4-5mm. So as a quick and easy solution I just cut a little ledge into the mount with the bandsaw.
And here's a shot of both axis's
So now I can use the X and Y axis as computer controlled to help make the Z-Axis mount. It certainly is easier to just type in a command to move one direction by 72.3mm than counting turns of the handwheel. And being able to spot-drill all the holes at once and then go back to drill all the holes without worrying that you are drilling in the wrong place is just great. I guess it is like having a DRO, but instead of reading off the coordinates of where you want to be, you just type in where you want it to be.
So, onwards and ummm ....... sideways?!?!?
Tim
Tim
