Peter,
My goal was, as you said, to first get the all the cylinders to a consistent bore diameter. I had a lot of time invested in their external features that I didn't want to risk, but I knew I could eventually lap them all to a common diameter even though at the time I didn't know what that diameter would be. It would just be a matter of me putting the necessary time into a process that removes material very slowly.
After finishing the cylinders I decided to make the pistons. The rings could just as easily done at this time instead since there really wasn't any close fits involving the pistons with either the cylinders or rings. By 'close fits' I mean fits that have to be verified by actually trying them because they may be too close to rely only on my measurement ability.
After finishing the pistons I'm now moving onto the rings. Even though I now know what their o.d.'s need to be after measuring the common i.d. of the cylinders, I won't be able to test such a close fit in the cylinders without risking damage to their finished walls until the rings are gapped. And, since the heat treatment may change their shape slightly I really won't be able to check their final fit until after heat treating. Then I'll use a light test to verify their contact patch to the cylinder wall. If the batch fails my light test it will be scrapped, and I'll mitigate my losses by limiting the batch size to ten or so rings which is the number my heat treat fixture can handle at one time. Scrapping a few batches of rings in my particular case at this particular time is much preferable to scrapping even one completed cylinder. The truth is, the scrapped rings will go into a labeled box and may end up perfectly fitting a cylinder in some future project.
My comment that you asked about concerning an undersize or oversize ring was trying to say that I felt it was better to be slightly over-size on the ring o.d. than it is to be undersize. The light pattern will show 2-3 very narrow point contacts on a slightly oversize ring that will quickly wear down to give a perfectly fitted ring. A slightly undersize ring will have a wide non-contact and a wide contact area that will take much longer to wear down and seal to the cylinder bore. It is totally a judgement call on what to accept and what to scrap. I will likely start out rejecting any ring that shows any light at all until my scrap rate is so high that it starts wearing me down. I'll then start accepting some slightly oversize rings.
Now I'll try to answer the main question of your post. If you're planning on using commercial rings I see nothing wrong with lapping your cylinders to the o.d.'s required by the rings. There is a slightly greater rusk to your cylinders in doing this compared with what I did, but what you are proposing is very reasonable and done by others all the time. If it were me, I would have the actual rings in hand before I started lapping and, in addition to actually measuring the lapped bores, I would perform a light test with the ring in its actual cylinder when I got close to the finished value. Once I was satisfied with the light test results I would make sure those rings stayed with those particular cylinders. - Terry
