Thanks blokes - it was a bit of a fiddle, but I was constrained to working with what I had on hand, hence the method.
Zee - I'm probably lucky, but my 30 y/o Pratt Burnerd 3 jaw still holds pretty true over most of it's range, so the procedure is/was this.
The ring started life as a scrapyard bronze bush - I got two of these years ago and this is the 4th (and last
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) flywheel I've got out of 'em.
1. Hold the ring in the three jaw by the inner diameter and face, turn the od down to a bit oversize.
2. Reverse in chuck and face other side down to a bit over the finished dimension.
3. Transfer to 4 jaw, holding by the OD and clock true. Then bore out the ID to size.
4. Bore a little step - no more than 0.005" or so, for the spokes to rest on.
5. Trim spokes oversize and mount on true running mandrel. Turn down to a close fit in the recess. (mine was a
light tap fit)
6. Assemble wheel and, still holding with the mandrel take light truing cuts until it runs true.
Mine has yet to have it's final trim, which it will need, as there is just a little 'float' in it at the moment - noticeable, but still better than some finished flywheels I have done. All in all I'm pretty happy with it.
