Thanks all, it was a great feeling to finally get it running. I have the itch now to start another engine, any suggestions for a good second build after I finish the "bling" on this one?
I found a couple of things that might be helpful to anyone new to this hobby like myself and looking to build this engine. The issues appear to be simply the piston and valve clearance. It truly does need to be as small as possible while still allowing a somewhat smooth movement in the cylinder. Clearance was about 2.5 thousands when I wasn't able to get it to run. After re-making the piston and valve the clearance is now 1/2 thousandths or 5 ten thousandths (I think they are one in the same?) and started up the first time I tried it, heated first with a blow torch for 30 seconds. The Alcohol used was the same for all trials so I do not think that was a factor in getting it to run.
Process for getting them to fit:
-Turned down valve and piston very carefully to 2 tenthousands oversized of the cylinder
-with them still on the lathe I used 1500 grit sand paper and removed the remaining material until it was a very tight fit in the cylinder, basically needing quite a bit of force to "wedge" it in. I then used Maas polishing compound and very slowly worked the piston and valve back and forth in the cylinder until it was a little tighter than a sliding fit. Then cleaned everything off and basically spent about 1 hour working them back and forth. Maybe not the best or most efficient way to do it but it worked for me.
The flame position as all on here have stated is also important and a little movement in any direction does affect performance. Both Bogs recommendations and the wick postions on the plans work great, any other postion and the engine simply stops as can be seen on the video.
A couple of questions/issues that still need worked out, any suggestions?
1. My valve push rod is made out of 1/16 stainless welding rod, I think it is too thin and bends pretty easily and I can feel some resistance because of the bends, I will move up a size to 3/32nds, hopefully that shouldn't affect much.
2. I still do not understand how to make it so the valve does not get sucked to deep, right now the push rod is long and hits the cylinder wall. Seems to work OK for me but others do not have to keep the valve push rod longer. What gives?
3. After about 10 minutes of constant running the engine seizes up and the valve is very tight, is it getting too hot and expanding at a different rate than the cylinder? Is that possible as they are made out of the same material.
Thanks again for all the help and words of encouragement, once I get it polished up and build a proper base and burner I will re-post a video and pic, I was thinking a high polish on everything with a custom brass burner and an engine turned base raised up on some pillars.
