Jos thank you that is a good idea and we were thinking along the same path but only square lifters.
I wanted to change the valve lifter design from the plans to one that had roller bearing ends. The original 1/8" lifter holes were enlarged to 3/8" for some brass bushings to fit in. I was concerned that if I used round lifters with a bearing they would try and turn sideways and bind up. (not good)
1/4" square brass stock with the roller in the end was my favorite style but how do I make a square hole in the brass bushings?
I could buy a square broach but that was too expensive and the brass rod varied in thickness so it would be a sloppy fit if I went that route.
I tried making a broach twice but that didn't turn out too well either.
I decided to machine the inside of the bushings on my CNC using a 1/8" end mill instead but that left material in the four corners of the square because the end mill is round. I could have removed the four corners with a file but decided to just cut the corners off the square rod instead.
Ten bushings and ten lifters.
Closeup of the lifters.
With the bushings installed in the housing
Thanks for looking
Ray
Thanks for looking
Ray
