- Jan 4, 2011
- 1,437
- 401
I never got the engine to run for more than about two minutes. At this point it is on the shelf and I have "borrowed" some parts like carburetor and ignition module. The engine seems to run best if timing is ATDC. The carburetor adjustment is super sensitive. 1/64 turn on the needle makes the difference between running and not running. As the engine heats up the carburetor has to be readjusted. I have tried several different throttle body sizes for the carburetor but nothing works well. As many of you know once you get most engines to run a minor adjustment in fuel mix or ignition timing makes the engine run better but does not necessarily make the engine not run.
As I said. Phase of the moon and plane alignment.
