Today I purchased some 1/4" silver steel for using on future projects and for making a 1/4" reamer. For reference a 1 metre length of water hardenable silver steel cost $15.00.
First I made the reamer my methods I read about in "The Amateurs lathe"
Method
Cut a length of 1/4 " drill rod to 75mm length and square both ends
put a small chamfer on one end say 1mm max
Then file the rod, in my case for approximately 12mm diagonally along its length. I had a very thin part to ream (3mm) . the amount of diagonal cut can be varied I found this worked very well. The book asks for this to be hardened, however it worked fin as is without hardening. I then proceeded to clean up the flat diagonal edge on the oilstone until "sharp" i.e flat.
The reamer is then used just like other hand reamers, Rotate in one direction only for inserting exiting and a perfectly reamed hole emerged.
The photos show the connecting rods clamped to the 1-2-3 block ready for reaming
I carried out the reaming in the drill press rotating the chuck by hand by moving the belt in one direction until right through and then raising the Chuck whilst still turning the belt in the same direction (you need three hands for this)
The drill rod is shown with a neat sliding fit in the con rod
I recommend this as an easy method of reaming an accurate hole as the rod could be turned to any size and then made in to a diagonally cut reamer
