An improved simple indexer
Macca
Based on Signal Failure's post http://www.homemodelenginemachinist.com/index.php?topic=2869.0
I started off by hacking off a bit of 40mm aluminium and turning it down to be a sliding fit in the spindle bore.
Then I flipped it over and turned it down to fit the bore of the change gears that came with my lathe, and whacked an 8mm hole through it.
I slotted the spindle end with a hacksaw,
and filed a keyway and matching key.
I tapped an 8mm thread in a bit of 10mm mild steel, turned a taper, then loctited in a bit of 8mm threaded rod.
All together:
The frame is just some aluminium angle riveted together, with a block of aluminium bolted on to hold the detent.
The detent is just a piece of 10mm mild steel, turned down for a section to fit a spring, and filed to match the shape of the gear teeth.
Here it is set up and in use:
It is worthwhile noting that my lathe has a safety interlock, it can't run if the cover is open, you can see the switch just to the right of the small pulley above.
Nevertheless, it is a good idea to unplug machines whenever they are used manually, it is just too easy to make a mistake.
I like it!Simple and effective.Give that man a cigar ;D
Yep, that's 'ow it's done, except I used the guts out of a masonry anchor for mine - saves all that malarky with the taper and the threaded rod
> I used the guts out of a masonry anchor for mine - saves all that malarky with the taper and the threaded rod<
Now THERE is a gem of an idea. A ready built expanding arbor.
Thanks.
...lew...
And also if you use the rawelbolt bolt type of masonary fixing the taper cannot turn when you tighten it up in the spindle the taper part is either a hexican shape or has little ears that pick up in the main bodypart, the taper might turn on Maccas tool! but could be overcome not that easily by putting a pin in the taper and letting it run along one of the grooves in the expanding sleeve it would have to be a pretty small pin though
Tel
that indent part of the tool you have fixed on your lathe (ML7)is a permanent fixture ie bolted on cause im am thinking of doing the same thing on my old Super7
Macca
i am not knocking your design, it is great! just pointing out what could happen, as i made a hand crank for the spindle of my lathe and without the pin (the taper was longer than yours and the slots wider, i used a 3/32 roll pin)the taper would roll when you tightened up and loosened, good design tho i will definately put on my list or "heap" as it is from this site
Regards Max.........
I did think of using a masonry anchor, thats where my idea came from. The only problem was I didn't have one small enough.
Max, I used a lot of loctite on the taper/rod, it hasn't slipped yet. I did think about pinning it but I wanted to use it straight away, so I didn't bother.
