The remaining aluminum needs to be poured out of the crucible into ingot molds.
I use steel ingot molds that are made from steel angle iron, with the end caps welded on at an angle to allow the ingot to release.
The ingot molds need to be preheated to perhaps 500 F before you pour into them.
I generally place the ingot molds in the exhaust stream of the furnace.
If you don't preheat the ingot molds, the slight amount of moisture on the surface can flash and pop the molten aluminum back into your face.
If you leave metal in the crucible, it could crack the crucible as it cools/contracts, and then expands when heated.
Some folks scrape out their crucible after a pour, but I have never done that, and never had any crucible problems.
All of my crucibles after the first off-brand one have been Morgan Salamander-Super clay graphite; one for each metal type to avoid contamination.
Here is a video of what can happen if the ingot mold is not preheated to about 500 F.
Needless to say, never wear synthetic clothes or shoes when melting/pouring iron, since it will melt onto your skin.
I had this exact thing occur with iron, and I had preheated my ingot molds, but not to 500 F.
I got some 3rd degree burns when some iron splatter ran down inside my gloves.
You want burn photos? I got burn photos.
What is the best type of fire extinguisher to use?
