Long ago I worked as a hot-dip galvaniser, which is primarily molten zinc with some small amounts of nickel, lead and aluminium. Our pot (called a kettle in galvanising) was steel and large amounts of steel and cast iron was lost to the bottom of the kettle to be fished out at the next dross removal shift (oh how I hated those shifts but we only did it every few months). Interestingly, we were told that copper in the kettle was a very bad thing and if we tossed in a 1 or 2 cent coin (which were copper back then) they would eat their way through the bottom of the kettle. Sounds like much the same as you were told but obviously different metals - and it's very likely that there was no truth to either story. Some metals don't play well (Gallium and Aluminium for instance) but steel/zinc/copper/cast iron work well together. I think those 'old guys' were pulling our collective legs and we were gullible enough to believe them.In a die cast zinc plant steel falling into a pot {pot metal}of zinc is a bad thing. The way the engineer explained it to me is that the steel in contact with the molten zinc and cast iron creates an acid that eats through the cast iron. Im not going to debate if it is an acid per say but you can clearly see how the steel eats through the cast iron when the pot is drained. I know this pulls the thread off track but i was amazed as a young guy to see how this happened. I found it especially odd because cast iron and steel are so closely related.
Light salt ( potassium chloride & sodium chloride. Degass the aluminum with calcium carbonate (washing powder) not to be confused with calcium bicarbonate (baking powder).Do you ever put some sort of flux in while you're melting the aluminum swarf? I've melted silver and we always throw in some borax.
Thanks. I'm looking for plans for a foundry I can build. Lots to choose from.
I already have an acetylene/air torch.
Oil will burn off. The steel will do as you said and either sink or float up as dross. Ke” View attachment 102755
Another similarity of the jobs, when I began working at the galvanisers I was replacing a 20 year old guy sent to the hospital with 3rd degree burns to 75% of his body (never found out if he survived) yet being young and stupid I didn't think too much about it. While I was there for only around a year and a half, there were many accidents and I had to (literally) run for my life on 2 occasions. I got out with only 1 serious burn and a smashed foot but many close calls. While I was employed we only had 1 fatality at the plant but I don't know how it wasn't more. It's so much nicer doing what I do now...Honestly when I left that plant after about 2 and a half years of working there it was the happiest day of my life. Conditions where bad and most of the people employed there where not the types you could trust with being safe. I lost track of how many times I drove into the place to find out that an ambulance had been called yet again to take somebody to the hospital.
Although what you say is true, the reaction with steel is so slow that it is not overly important if the crucible has a decent wall section.Dont melt Aluminium in a steel crucible the Aluminium eats it. Graphite crucibles are cheep.
