Kpar
Kpar
I've had this Lathe for some time and have enjoyed making a few trinkets to get some machining practice. I've always had some difficulty in parting off and I'm now up to my 3rd tip holding blade and is getting a bit frustrating.
Done a lot of reading up and have followed these tips from others
1. Tool height set correctly
2. Blade parallel with chuck face
3. Speed set as per stock size.
I usually brake the blades on old axle steel. This morning i machined up a 30mm x 150mm center to hold in the chuck and broke another blade.
What I noticed just before the blade broke some shudder was experienced & the nut that holds the cross feed handle had backed off a little. Maybe this was the shudder. Trouble is if I tighten the nut very tight it seems to bind up the cross feed.
Sorry about the long thread but can somebody help me out with some suggestions. Parting off is getting expensive (back to the hacksaw)
Kpar
Kpar
