Hi everyone
I need to replace the x2 main backgears on my ML7 as both the bull-wheel (one with the small tooth selector) and the gear wheel below that on the eccentric have lost teeth. I have got the replacement gears from Myford and have installed/replaced the lower gear with no problem.
It is with the dismantling of the spindle where I am stuck - I have taken the small gear off the rear end of the spindle followed by the travel adjuster and ball race no problem.
It is the friction/interferance fit spacer/collar behind the pulleys that I can see no way of removing. Can anyone help me or advise? Many thanks in advance.
Roger
Roger
