Today I cut my very first metric single point thread! :big:
I have been working a 3 3/4" diameter lump of mystery steel down into the shape of an ER32 collet chuck for my 7x12 for the past several days. Today I finished turning the collet boss to diameter (40 mm or 1.575 for us Colonial types) and single pointed a lovely 1.5mm thread for the closer nut. Considering my lathe is Imperial I was a bit nervous about cutting metric threads on it. I was worried about nothing as it turns out! By a stroke of good fortune my new control board does not require that the speed be set to zero before reversing the motor. So it was a simple matter of one hand on the F/R switch and one on the compound. Back and forth, pretty as you please, until I had about 2 full threads engaging on the nut. Then I switched over to a double cut 3 corner file and dressed the thread until I had a very snug fit. A quick polish with 200 grit emery to clean up the ragged crown and the nut spins on and off like silk. Here's a video of the final result. (Sorry about the loud radio in the background)
http://vid797.photobucket.com/albums/yy258/websterzdesign/er32chuck.mp4
