Glass bead or abrasive blasting is something that doesn't come up too often here. As a means of obtaining a uniform, pleasing finish, it's hard to beat.
A few years back, I invested in a benchtop blasting setup, and filled it with glass beads. At 80 PSI, a few passes with a cheap gun does nice work. Although it looks anodized, the body parts of this gadget were glass bead blasted:
Now comes the question... glass beads are outstanding for aluminum and copper alloys. Something like aluminum oxide, though, is generally needed for ferrous objects. I do a ton of aluminum work, and prefer to leave my bench rig set up with the beads.
Alox media is expensive. Does anyone know a way of either recycling the media, or capturing it somehow, without having to invest in another cabinet? I tried it a bit outdoors using a plastic was tub, and the media simply went everywhere. I'd guess less than 20% was captured by the wash tub.
One thought I had was using a cheap media like sand, but typical play sands are too coarse. BTW, media with silica (like sand) is very dangerous to breath and requires the use of a respirator or other clean method to avoid inhilation.
