1hand said:
Man thanks a Million for hooking me up. I really like the looks of that finish. Being most of my loco will be of steel may use that on the whole thing. Would give for a different look than what most do for a finish of painting black. It sounds like alot easier than painting also.
A few more questions:
1) Any bad fumes to worry about
2)any special prep to the parts "like wipe with mineral spirits first" or a light media or sand blast
3) do the parts have to be subspended, or can you just throw them in there to get a good even finish
4) do you treat the parts after like you would a gun "light coat of gun oil periodically"
5) do you get the same results with 12L14 and 1018 steel.
6) what about cast or durbar
7) I have a huge turkey cooker pot, but its aluminium, Work or no?
Sorry for all the questions!
Matt
1) Not that I know of. But read and follow the instructions that will be included with the product
2) degrease thoroughly, and do not touch with your fingers afterward, even if you wash them.Blasting with media is to add texture not intended as a way to clean the surface (the media might be contaminated).
3) must be suspended with wire to get the solution evenly all around the part.
4) yes, oil initially and wipe on a little after you handle the part, just to be sure.
5) I haven't tried it on 12L14 but I think it should work.
6)I haven't tried it on cast iron but I think it should work.
7) No aluminum. You must use a stainless steel pot and anything that will touch the solution.
I use a cheap garage sale 2 QT pot with handle , heat on K-stove, check with a thermometer and turn the heat off when it reaches 180-D, click heat back on when the temp drops to 160-D. Its very easy to do with just a few basic rules to get an even finish
Best time for parkerizing is when "Honey" is out and about! ;D
-MB
