- Jun 28, 2011
- 238
- 480
Well my steam powered sternwheeler http://www.homemodelenginemachinist.com/showthread.php?t=22191 is fun to run, but it is a real event to get 50lbs and 6ft of boat out to the water and back. I want something I can toss into the car and steam on a pond with little effort and support equipment.
I am going to start with the running gear to get an idea of weight and from there I will find some kind of hull that will hold the running gear and be able to handle a little bit of waves. Right now I have to go out on glass smooth days for the Liberty Belle.
So here goes...
I have a chunk of 3 inch copper pipe stamped with an 'L' left over from the first boiler I built. I want to make a vertical fire tube boiler this time. I cut off a chunk of the pipe, heated it up and formed that plate into the end caps. It took many heating cycles to get the metal to bend around the wood form blocks. I used a flush set in my rivet gun to do the work for me. They seemed to come out pretty good. It sure is amazing how much the copper will bend and form. I am basing the boiler on drawings in a book called Model Boilers and Boilermaking by K.N. Harris. It will have a 3" dia x 5" tall shell with 37 1/4 OD fire tubes.
Here are the pictures
Pete
So here goes...
Pete
