K
Kermit
Guest
A magneto generator. Actually it is a science project for 5th grade. I did the part creation and he put it all together.
Magnets are ready for mounting but finding a way to keep them apart, adjust their spacing and provide for easily disassembly; all at the same time, is slowing us down at the moment.
I'm going to start with a pole shoe of some sort up next to the rotor. It will be an arc to provide equal spacing around the rotor. Next the magnets will be mounted. I'm going to drill and tap the pole shoes in two places for bolts. Probably 1/4 twenty bolt, and by using stainless or brass the magnets can be dislodged from the shoes far enough to be able to pull them off by hand. Mounting is pretty much figured out as well, but the sticky point is a way to adjust the air gap around the rotor with the magnets in place. The magnets will hold almost 300Kg in a dead lift when put together in a row. The adjustment will have to be of 6061 or stainless or some other non magnetic alloy.
Anyway, thought someone here might find this interesting. The reason for the awkward rotor assembly was to make it 'see-through', and therefore the use of plastic. The other reason was the use of powdered iron filings for the rotor iron. Stamped sheet steel fabrication being out of my reach technically right now.
Kermit
Kermit
