5c Collets...
b.lindsey
Collets can be handy for some things, not the least of which is accuracy...but that accuracy is going to be dependent on accuracy of the chuck, collet holder, fixture, etc. that the collet fits into. I would evaluate the accuracy that you can build into the chuck first or that advantage of the collets themselves will be potentially lost.
Bill
The lathe I used at school had a nice Sjrogen collet chuck, and was very convenient.
At home I don't have a 5C chuck for the lathe, but do have a set of collet blocks. These are most useful for milling hex and square profiles in round stock. They are also useful for holding round pieces for vertical milling/drilling when v-blocks are too large.
If you haven't built model engine parts using collets, you don't know what you're missing! You will love the ability to remove and replace parts with minimal runout, and the avoidance of jaw marks on the parts. I'd never go back to using only jaw chucks.
Collets are very nice, but I'd also check out the ER series (ER-32 / 40 or so) as well-- 5C collets have a very narrow working range, so you need a huge set to cover all sizes of material (if you only use certain sizes, then you can get by with a lot less of them). ERs cost a little more per collet but have much larger range. ER seems more popular in Europe, while 5C is all over the place here.
Of course I don't think you can get ER collet blocks or spindexes or hex or square collets either, so if you want those, the decision may already be made.
Paolo,
Good advice so far!....you chuck needs to be very good to take advantage of the 5C accuracy....but it will need to be good for any collet chuck.
Turning the collet mounting surfaces with the chuck on it's mounting in the lathe on which it will be used is your best bet.
Yes Dave...this is my intention. I'm intend to prepare the two pieces from another lathe, bigger one for the rapidity, and after mounting the fixed part on the back plate of my 7x12 proceeding at final works like internal&external treading ..after that I can try to prepare the twisting collet...My choice will be between this two sets...: Set of 30 Gloster Hardinge type 5C collets 1-30x1mm at 169 Euro or 19pc 5C Metric Round Collet Set - 3mm to 28mm at 123.50 Euro. I'm considering, after the received answers,also the ER type collets because of I have 7 and I use that set on my BF-20 mill...
Cheers Paolo
Try the bottom of the page on here
http://www.arceurotrade.co.uk/Catalogue/Collets/5C-Fixtures
The adapter is available from nowhere else, as it is designed by John Stevenson, and manufactured exclusively for Arc Euro.
This allows you to hold your ER 32 collets in your 5c fixtures. Also the Stevenson spindex unit (middle of the page) is again unique to Arc Euro, and you can hold both ER32 and 5c collets in it. The adapter in the spindex unit can only be used with that unit, so it is not possible to buy just the spindex unit and hope that the adapter in it will fit into other 5c units.
They are out there, but just take a bit of finding.
Blogs
Nice find Blogs....thanks for sharing that. :)
Hi Blogs
Thanks for your nice suggestion!!!
Paolo
Problem with ER collets is, you can't clamp the very short things.
Rego-Fix (Inventor of ER collets system) says:
"Insert tool to the full length of the collet for best results if possible. However never insert the tool less than 2/3 of the collet bore length.
Improper tool insertion can permanently deform the collet and will result in poor runout."
So if you want to clamp short parts, you need to put another piece of material inside the collet which has exactly the same diameter.
With 5C collets you can even clamp very short discs and machine them. But you only have the nominal diameters.
For special diameters, you can still make a slotted sleeve.
I personally would prefer the 5C system; using a collet chuck (looks and handles like a 3 jaw chuck but has a nose for 5c collets: 5C collet chuck)
Florian
Hi Florian
Thanks for your advertising! I wasn't noticed about the problem clamping short pieces with ER collets. I suspected it remembering a difficulties encountered clamping shortly an end mill, some time ago, due to a particular work. It would be nice to have the Colet chuck but I have two order of problems..First my late is Small, like a Grizzly 7x12, and "costant" temporary money shortage!!!! :big: :big: :big:
Paolo
Paolo,
Bison makes a version of that 5C collet chuck but 100mm diameter.
It is lighter and smaller.
I can't seem to find a place selling it in europe at the moment.
New England Brass and Tool sells them, but not as cheap as arceuro.
Paolo:
for a 7x lathe I would lean towards a 3C collet system this would work the way lathe collets are meant to and give good flexibility up to 1/2 round . yes 5c collects are more common. I use 3-Cs in my South Bend 9" on a regular basis. There are also 3-C pot chuck that are not too bad in price about $30 US. These are available in 2 and 3 inch sizes an are machined as needed to size.Another way to reduce run out and marring is to get a chuck that uses soft jaws. this is a great feature of the little Sherline lathes.
At one point I was going to build a 5C adapter for the SB but ended up deciding against it.Metalworking book one acualy has two versions of a 5C adapter the Pat Loop collet chuck and a collet adapter by Phil Dulcos. So these can be another work holding tool to add to the mix. IMHO I thnk a bit awkward for a mini.
Maybe seig or someone will build a tabletop hobby lathe with a #5 headstock.
If i had to make a 5c collet cuck for my lathe, i would make it that way:
http://www.cnccookbook.com/CCWishListBiggerProjects.html
(Scroll down to the fifth project... )
But i don't need to make it because i own a Swiss Schaublin lathe which has the collet cone included in the spindle nose...
Its not working yet; i am preparing to paint it. Then i will have to reassemble it and as soon as i have reassembled it, i will be able to turn with my own lathe ;D
Florian
Hi Florian...
my set of 5C collets is on the way...I'm trying to find a right planetary reduction for doing the magnificent chuck holders as you showed...quite impossible at moment here in Italy..Thanks anyway.
Paolo
Paolo
I've just seen that you're from italy; I live in Switzerland... ;)
The planetary gear seems to be from a transmission. Maybe you can find one on ebay or somewhere they repair trucks or cars. Or you may write an email to the guy who made that collet cuck.
One possibility also is to make the gear by yourself. But you need a rotary table and a rigid mill with a sleeve.
Of course you wouldn't be able to make helical gearing like that transmission gear on that homepage has...
Florian
Hi Florian
nice to ear that! I went in your country some years ago..but anyway...I'm on the way , after the engine project finishing, to build myself an 5c collet chuck starting from an idea found in a site!
Thanks anyway...
best regards
Paolo
At present time 5C collet set is on my drawer..waiting for...
a Little case built around the rack received as gift from seller...
And the chuck!! Until now I didn't found a planetary transmission so I decided to proceed myself!! I based my project over the Ty Hoeffer Prototype...I made a drawings and started the costruction by two C40 round chunk...Unfortunately I lost a folder with the initial works...Sorry!!
I did completely wrong the internal tread of the rotable part of chuck..so I decided to do it again in a separate collet and after insert it into the collet tightener and silver soldering...
another one...
another view
just after some pickling into Citric Acid..
Ready to assemble...
At first attempt I used tree hinge, like a chuck, but I wasn't able to reduce to "0" the runout due to small lack so I decided to use tree Allen screw with bolt...
Finally the test.....
not bad....
I decided to proceed at some grinding for reaching more precision so I did it using my bore grinder mounted on the late..
This is the result...In the after noon more test will be conduct...
Paolo, you're doing a great work with that collet chuck
the runout is enough good now, if you can get a bit better it will be perfect
anyway, I think that now it is already better than many lathe chucks
