I ran nitro top fuel dragster funny cart and alcohol funnycars . The fuels sr really corrosive . After each run we ran the engines on non oxy gasoline to purge fuel out of lines and engine . Then we disconnected all fuel lines and drained remaining fuel out usually a spray of marvel oil air tool oil was enough to finally clean. Seems like a lot but losing a round due to leaky fuel line was very economically a big mistake often in the thousands of dollars . Technically we could have just tossed fittings and used new
Just keep in mind that is very much NOT tolerant of non polar solvents like petrol (gasoline in freedomspeak) and engine oil. Nitromethane, methanol and castor oil might be ok because of their more polar characters.we had a portable gas tank with quick connect fittings there were no plastic fittings O rings were critical so we used lots of them just for the fuel the throttle valve was very sensitive so these were changed every race day. I used nitro in my pattern planes as I used ducted fan engines again model fuel lines were not the best so I went aftermarket to Parker co. They directed me to recommended o rings and fuel line materials . It’s been a longvtimecsoni just don’t remember exactly what was used they have pages of specs available so it’s pretty easy to select the correct materials I only used non oxy premium gas in my giant scale planes and yellow Tyson fuel lines standardcrc tanks worked fine. I did change fuel lines often just to make sure also I used standard Klotz two stroke oil Various ratios generally 40 to one.
