- Jul 8, 2009
- 774
- 250
willray:
I agree, I'm already down the rabbit hole, that's why I said I didn't want to go TOO far down it.
Somehow I managed to fumblefinger my printer profiles in S3D, I deleted them. Using the factory default settings in my D6 printer I have significant discrepencies between my 20x20x20mm cube and the actual measurements, X was about 0.5mm out and Y was worse, but Z was fairly close. This would be fine if all I was printing was artsy-fartsy type stuff like pencil holders and dragons, but I'm trying to print actual usable parts - parts that will fit to something else without fettling. So far I've printed 20 of the 4" adapter rings for my dust collector project and have at least 6 more to print - so NO fettling.
The cube errors were inconsistent between the axis so I couldn't write it off as a scaling issue. I had the same problem on my I3 clone, and this calibration procedure of the steps/mm was how I fixed it. I am currently sacaling all 3 axis in the slicer to 103% to compensate for shrinkage, so even though the parts are built using the equivalent of Lincoln Logs the part SHOULD be close. I agree, a thou or so error from a 3D printed 20x20x20mm cube isn't bad, but when I print a larger object and the error scales up with it, THAT I can fix - at least get it closer. When I can print a small part, and a larger part, with about the same error, then it's time to click my heels together 3 times and leave OZ. (Sorry about the mixed references, couldn't remember how Alice left Wonderland.)
S3D doesn't have a printer profile for my MP10. When I tried printing a 20x20x20mm cube, I got a 20x20x10mm cube. I found several references on the ole Interwebb suggesting that this or that printer profile would work - for me, not so much. This wasn't really that unexpected, the Z axis lead screws on my other printers have a 2mm pitch, and the MP10's Z axis lead screw has a 1mm pitch. So I had to fix the calibration on the MP10 too. I load the new steps/mm setttings in the g-code when I start the print, then reset them at the end of the print. I may not have to do that, but the MP10's got a bed leveling function built in and I didn't want to screw that up.
I'm not too concerned about the accuracy of the Z axis. Unless the 3D printing gods smile on me and deliver a miracle, that height could be off by up to 1/2 of the layer thickness. If I'm within that +/- half layer thickness, and it stays that way with when printing a larger object, then Z is "crose enuf".
Don
Don
