- Dec 12, 2012
- 2,220
- 1,288
any drawings or photos please.Just a note,i tried out the smallest boring bar
boring to 15dia from 13 dia hole.I had to grind the tool at the underside
to give clearance at these small sizes and also grind more front and side top rake.I assume when I use the larger sizes on larger diameters it will not be necessary to grind additional clearance
Also on a previous toolholder I fitted the TP in posn and drilled/bored from the lathe to get centre height exactly.This caused problems with the cutting tip
being higher than CL with these boring bars,so I made a 12dia boring bar
with HSS insert for this station which also uses the 10mm dia boring bars
hopefully I now have enough of all I need to bore.Boring but true
