Hi, I am new to this forum, been involved with Historic Racing cars for a long time and wanted a change of pace as between projects now. HMEM has twice now asked that I post what I am up to - so here goes !
Flew control line as a kid - always diesels as couldn't afford the "accumulator" battery Glo's needed. Had a Taipan maybe a Mk5 red head plain bearing, dug it out of the dirt a few times, but it never let me down and sold it to buy a model train. Dumb I know but was only about 12, that was 1960.
Have used my Mill and Lathe thousands of times for machining things around racing cars in rebuilding and racing them, but wanted to do something to hone those skills so what better than something that might work when finished. These cars are the Brabhams, Lotuses and Elfins single seaters of the 1960s. I am self taught on this machinery. I sat in an Airline's ops chair for 30 years, no place for the feint hearted, as you are the first to know of a problem as you are the one responsible for getting around that problem and keeping the passengers happy, but working shift work it does allow another life outside of work - hence the racing car thing from early 1980s.
So my first project was the BollAero 18 - what a great project to start with - not too difficult and individual pieces that bolt together. Really surprised myself as this engine turned out really nicely and it ran well on very old ether, Castrol M and Digger's kero.
Next was David Owen's Owen Mate. My first attempt at carving a crankcase from solid - and it turned out ok, but about 30 hours to achieve. Then everything else was pretty straight forward and it ran well but only a few minutes as the gudgeon pin came loose and scored the bore. Then 2 more piston and cylinders later I couldn't get it to run, so called in to see David and he showed me the lap from his plans of the Owen Mate and when I made and used that - success. It runs beautifully now with a lot of power.
Third was a copy of the Mills from plans bought from Ron Chernich. What a joy to build and it runs from no more than 3 flicks !
My 4th engine is something I am developing from the Owen Mate. I intend to use a ball bearing either end of the crankshaft, increase the stroke and bore by 1 mm each to give 2.46cc and have the crankcase cast by a local company here in the Sutherland Shire (Sydney Australia) called Camcast who looking at the pattern yesterday with as far as it is developed, say it will be no problem and about $30 including heat treatment.
My next project car wise is about 2 months away - so hopefully the Holly modified Owen Mate might be close to finished by then. If you are interested in old racing cars I do a newsletter and the latest is a day or two away from being on the www.hsrca.com website but if you want to see the last one from 3 months ago - go to http://www.hsrca.com/wp-content/uploads/2013/04/MO-Newsletter-22.pdf
Pictures attached below of the 3 engines and the pattern as done so far.
Ed
Ed
