grizelli
Active Member
- Dec 24, 2013
- 30
- 8
The title sums up my problem, but this is not your average engine
Its a 2 cylinder 2 stroke, running on petrol, with horizontally-opposed pistons and the spark plugs in the centre of each cylinder. It uses a small vane-type supercharger to scavenge the cylinders, and the inlet piston lags the exhaust by around 15 degrees in order to give a small amount of supercharging to the charge after the exhaust ports are closed and while the inlet ports are still open. For those interested, the design is loosely based on the Tilling Stevens TS3 engine which was built in the 1950s and 60s in the UK. The carburettor is a stock model carb (made in the UK by Just Engines) with a bore of around 7mm, and the ignition is provided by a Rxcel CDI box. The engine is quite large, bore is 30mm and stroke 30mm.
I've been spinning the beast with a drill for several days now, and all I can get is encouraging pops and bangs and the occasional flames out of the exhausts, but it won't pick up and fire continuously and won't run on its own. Its set to fire at around 15 degrees BTDC, but I have tried various settings from 0 to 30 degrees BTDC and it seems to try hardest at around 15. A clue may be that it pops and bangs most enthusiastically with the throttle around 1/3 open, pretty dead either side of that point - I've played with the mixture a bit and it seems to like it lean rather than rich, but since it won't run its kinda hard to tell.
The pictures give an idea of the engine, please note that the oil pump works surprisingly well and accounts for the pile of clean-up rags . I know that there are a lot of knowlegeable people on here, and several of you have experimented with unusual designs so I'm hoping for some suggestions to get the beast started. Help!!!!
