ShedBoy
Senior Member
- May 13, 2011
- 792
- 34
Using a common crankpin arrangement as in the classical four stroke V twin however - although it might run, won't be of much use unless you use some sort of blower arrangement.
3. super charging....usually positive displacement type with a displacement a bit more than the combined cylinder volume. vane style is popular for models and roots is used on full size engines... a centrifugal may work on full scale but on model scale I doubt it (centrifugal chargers don't scale nice and are harder to engineer because they have a pressure per tip velocity relationship rather than a volume per revolution relationship.) super charing has been done on model radial engines
dman, I am going to start a new inquiry post specifically related to SC/boost for model radials, so I don't want to derail this 2-stroke post.
But in the meantime, can you provide any links or references to your reference "vane style is popular for models". I'd be interested to see details of what work has been done on models, how much boost they provide, how they are constructed etc.
I've seen pics of the Hodgson 'centrifugal device' applied to his radials. (I've callled it device as I'm not sure its a centrifugal SC. Ive heard it called a combination mild booster / flow disperser, but I'm not qualified to say in any event).
whirlywheel construction & assembly near bottom of build pics
http://picasaweb.google.com/18.cyl.radial.engine/HodgsonRadial18#5293775425552828066
cad sketch under crankshaft assembly
http://thebloughs.net/hobbies/metalworking/hodgson9/
Blower Charged Two Stroke Engines
Model engineer 1971 issue 34(12 13 14)
M.Hollick
Not a Freak!
An interesting early V twin 2 stroke engine is at the Sammy Miller Museum in England.
Search for images in Google etc.
A brochure can be seen here: http://reddevilmotors.blogspot.com.au/2012/06/stanger-two-stroke-v-twin-1919.html
It has two separate crank chambers.
I think it could be possible to have a common chamber on a V twin, if the crankpins were staggered so the pistons went up and down in unison?
My wife made me sell my MZ - she said it was ugly!
Jordan
i hope not to start a flame war but what makes you believe this? i'm actually liking the idea of a common crank pin v twin, or better a v4. why use a common pin? well i don't see the point in a v2 if the cylinders are phased the same. may as well make a boxer or big single.
Pistons are not really good for controling exhaust.They go unround and may loose temper.Valves are much better.
A 2400 rpm two stroke exhaust valve behaves like a 4800 fourstroke and can be pushrod.
It is now time for drawing
a common pin twin may need more timing and more tuning of port angles and may idle unevenly but by my quick math, not considering the rod:stroke ratio the displaced lower end volume is about .707x the total volume of the two cylinders. once you factor in port height that should be enough to evacuate the exhaust from the cylinders but it may need a little more timing than a single cylinder and it may be more sensitive to port angles.
"i hope not to start a flame war but what makes you believe this? i'm actually liking the idea of a common crank pin v twin, or better a v4. why use a common pin? well i don't see the point in a v2 if the cylinders are phased the same. may as well make a boxer or big single."]
That would just be a matter of preference I guess - maybe a boxer or big single would have nicer sound or better looks, - but no doubt there is some very good reason why a common pin 'V' arrangement is never seen in use on a two stroke, so you should perhaps try it and find out why.
The 'V' angle will have a big effect on your volume calculations too, - I was envisaging a 90 deg. angle but a much smaller V angle would be getting closer to single cylinder territory.
Also, I'm working on the assumption that you would be using normal transfers, but with a narrow angle V the closeness of the cylinders would cause the transfer passages to "tangle" (food for thought).
It probably will be necessary to have seperate bulky exhaust chambers, - (always a problem on two strokes), but again, it depends on the application it is to be used for.
[ "a common pin twin may need more timing and more tuning of port angles and may idle unevenly but by my quick math, not considering the rod:stroke ratio the displaced lower end volume is about .707x the total volume of the two cylinders. once you factor in port height that should be enough to evacuate the exhaust from the cylinders but it may need a little more timing than a single cylinder and it may be more sensitive to port angles".
Not sure what you mean by "more timing" - to me that means longer duration, ie. earlier opening and later closing? - (depends on where we come from I guess!).
That I think it would be extremely difficult to calculate and it will depend very much on the design of the exhaust chamber. There will need to be a huge amount of trial and error experimentation to get it right!
By "port angles", do you mean in a directional sense or crank angles/port timing?
And some people think that the two stroke engine is simple!
BTW, - Not saying you are wrong at all,- no contest! - just trying to get my head around the concept by bringing some points, which I consider to be valid into the discussion and I would like your comments.
i admit a common pin v twin 2 stroke is messy. i wouldn't expect it to be considered a good idea but i kinda want to try it.
