rodw
- Dec 2, 2012
- 1,146
- 340
Don't forget that a motor will only draw maximum power at maximum load (torque). So if you are going to use the ratchet on a drill motor to protect from over travel, you will not be anywhere near a full load situation so power draw (amps) won't be anywhere near the rated capacity.
MCRIPPPer, if you had a surplus laptop power supply rated at 3.5 to 5 amps, I would give it a go. Worst case is it won't work as they usually have overload protection. Remember that typically in a circuit you would have at least 20% headroom in any specs so your 12 amp drill will probably only pull 10 maximum and on a SX2, probably a lot less than that. The only way you would know is if you put an amp meter on it while it was running.
I had an electric motor tested recently, it was rated at 12 amps on the plate and it was only drawing 6 under load which the repairer said was about normal. Work that out!
I would not get too worried about how much current it draws, my experience with cordless drills is that you know when they are working hard cos you can smell the battery and they don't last very long at that power level. The power feed is never going to tax it at that level and I expect it will be close to idle.
