With the Tender mostly completed I turned to some of the details that connect to the tender.
First up was the roller guides for the cable. The rollers made from drill rod actually work.
Next I made the jack screw and clamping band for the brake. The band was salvaged from banding used to hold band saw blade material in a roll. It was a perfect size and it was springy.
I followed that with the quadrant for the control rod that will but the engine in forward, neutral or reverse. It still needs to have notches cut into it but that will have to wait until I have the engine built.
I altered the plan by putting the valve for the return water line from the water pump inside the water tank. I soldered the valve to the bottom of the floor plate just below the steering wheel. The valve can be turned by an extension that puts a control wheel near the top edge of the tender.
The final detail of the tender is a bulkhead that provides a bin for coal.
With the tenders details completed I went ahead and put the final finish to it as I dont think it will be separated from the model again. Most of the parts I plan to let age naturally, but the tender looked rather bad after soldering and cleaning around the rivets proved to be difficult. So after sanding and burnishing I used some acid and burnt oil to age it a little and then hand rubbed it with lanolin and light oil.
I have also completed the steering system. I bought the worm gears as Im not up to that challenge yet. I did make a change to the original plan when making the drum. I made it in two parts so that when the chains are installed I can rotate the two halves to adjust the slack in the chain before locking the drum in place with a set screw.
Well I cant put it off any longer so next up is the wheels. The hubs are done so its time to make the parts for the rims and the spokes. And then I need to make an assembly jig for assembly. Unfortunately my wife wants some work done in her kitchen so I may not get to start for a few weeks.
Mark T
