Shop-Built Slip Roll
Someone asked me about the plans, and that caused me to look back at this old thread. I don't need the slip roll often, but it is very nice to have when I do need it! It continues to work to my satisfaction.
About the gears ... I had the idea to use my 3d printer to print out a couple of different set of gears to try. I figured they'd tear apart pretty quickly, but they would let me test engagement at different thicknesses. Well ... it's been three years now, and I'm still using the 3d printed plastic gears! It turns out that there is not a lot of force exerted on the gears, since friction makes the rollers want to roll. The gears do help with feeding in the piece, so I'm glad to have them. And one of these days, if they do break, I can always go ahead to make them out of steel or brass or whatever is handy. Or I could just print another set ... !
I built a small one years ago for a specific project it got lost somewhere
Byron
He one I built looked almost exactly like this one I built specifically to form race car fuel tanks I made about 2 dozen fuel tanks and about the same number of over flow catch tanks . Secondary use. Can you believe some body stole it. At about $3-400. Per tank I guess I got my money worth . I had about $20 worth of material in it. It took about 30 minutes to cut the tank band about another 30 to bent to shape. About one hour to TIG weld so I came out pretty well I guess. Hope the poop chute that took it got his male glands caught in it LOL
Hi MRA,
Can you please share the exact gears you used for the 1” rollers? I am working to make one of these.
Hi MRA,
Sorry I can’t help much my rollers were about 1 1/2 “ by tightening the rollers together very tight I got away from much spring back. I used 3,000 or 5,000 grade aluminum mostly. As it welded so nicely gears were about 1” wide. I don’t remember the pitch. I just hope whoever stole it gets their right peck caught in it . LOL
Apparently you can also use a chain drive.
Or use Myfordboy's gearless design.
See 3:02
(Side note: He builds a fully iron-capabable foundry, and then pours the flywheel in aluminum, and goes to a lot of trouble to mimic something that he could have cast in gray iron in the first place; absolutely no logic to it at all).
