raveney
I saw a lot of really nice hit and miss engines last year at a local event. One that I had never heard of is the subject of this build. I have researched online and hadn't seen a set of castings or plans so decided to have a go at it from scratch.
The engine pictured is of unknown HP, but I am aiming at a 2 HP version. Some engines were paired with a cooling tank on a wagon and labeled "Jack of all Trades". I really like how the flywheel hubs are split and bolted to the shaft.
Vintage Machinery has good quality printed catalogs that were used to make a jpeg image and import into CAD. I then made some ratios to scale it to several constraints that I have for this project.
1) flywheel must be able to be turned on a 9x20 lathe. 8" nominal is good size on a faceplate.
2) cylinder size should be close to 1 inch, so I can use my existing honing equipment and boring bars.
3) cylinder jacket and crankcase should be close to nominal pipe sizes so I can fabricate using scrap metal I have access to.
I plan to silver braze or TIG braze the most difficult part: the crankcase. I modeled these dimensions off a buildable crankshaft with 1/2 journals and 3/4 stroke. The original engine uses a cast iron crankshaft, but I will likely fabricate one from mild steel.
I think I can use 3 inch nominal sch 40 carbon steel pipe and 3/16 steel sideplates to makeup the crankcase. The fillets will be JB welded after the parts are brazed or welded in place. E-bay has an original part that the seller had many pictures of so I was able to reference all of the features and attempt to figure out how it should function as I go. I plan on sharing the drawings for each part on this build and look forward to having others share the build experience or offer recommendations.
