Mystery steam engine
The small launches tend to run steel boilers that can make 200plus psi these will work with say a Stuart Swan or Cygnet and I don't doubt this engine could power a small launch. Some typical boiler shere
https://steamboatassociation.co.uk/SBAS-BoilerDesignLibrary
Not always easy to get a triple compound to run on air if built to the drawings. You need to play about with the eccentric positions a bit and may also need to feed HP steam to the IP cylinder. Or resort to leaving out a valve or piston altogether.
Hi jason
No need thats correct they turn straight out
Make tool an measure
See my lathe
Regards chris
    1.4 MB
    2 MB
    1.6 MB
So it looks like there are four rings of holes in the round steam chest and a slot top and bottom.
My thought are that the central two rings of holes (red) are cored to the inlet on the side of the cylinder
The top ring of holes is cored to the smaller HP cylinder and the lower ring of holes cored to the bottom of the HP cylinder. (blue)
The two slots are cored to link the two valve chests together taking the exhausted HP steam to the LP valve chest
This means that the piston valve can be solid as the exhaust does not have to pass up and through the piston and then feed via a single slot.
What we need to know is the diameter and vertical poiition of the holes as sjown by the green arrows. If you cross dril the shaft of your measuring tool to take a small piece of rod then that will allow it to be used in the holes.
    22.6 KB
On the slide valve dimensions did you make allowance for the thickness of the disc on the end of the rod? as the ports seem smaller than the rubbing suggested.
Also where you have sizes at the top of the drawing and at the bottom are they measurements either side so the 55.5 and 53.9 indicate the port is sloping?
Hi guys
Sorry for the messy drawings
It was late and i had to go to bed
I make a point on charles tool
Then i maybe can measurevthis hohles also
Regards chris
Hi guys
Regards chris
Hi jason im about to measure does hohles
I also remeasured the triangular chest
I discovered 3 hohles on the bottom
Of the cylinders
Maybe for cocks to get rid of water?
    2.1 MB
Yes exactly
I took of course internal and external
Of the disc
Its because they got a phased edge
On that one i almost couldent stick it in
I also got the round now
Chris
    1.7 MB
Yes those three holes are most probably for drains.
It looks as though we now have some pretty good measurements of the porting. I will have a more detailed look later. Moving on to the next part of the puzzle, I have some questions about the valve gear.
Are we happy that we have an accurate measurement for the stroke of the eccentrics?
From several views of the valve gear it looks as though the pins on the two sets could interfere in the middle, can they, or is there actually a clearance?
How are the eccentrics fixed in position on the crankshaft? Are the eccentrics made as a pair in one part for each side, or are there four separate and independent ones?
Hi charles
Do u want
to remeasure the crankshaft?
I can do so
Bud first the pics from valvegear
They interfere
Well without the rod
Otherwise just clear
    1.8 MB
    1.8 MB
    1.6 MB
Almost looks like they took the design of the valve gear from another engine that had the valve on the ends and failed to allow for them being too close when central.
First step would be to see how those central pins are fixed to the curved expansion link, hopefully they may unscrew but possibly soldered.
I had a bit of a play with the measurements and this is what I have come up with, comments welcome.
For the slide valve I have plotted the port at their widest using the two sets of sizes that should represent when they are uncovered. There is a bit of overlap just incase there is more irregularity in the ports. Possibly wants a slightly larger overall valve height to make sure the exhaust opens before the opposite inlet.
I have only shown one hole at each height on the HP valve and they work out quite close to a spacing of 1/2", 3/8, 3/8, 3/8, 1/2" which is not bad considering they would have been cored. Again some overlap to be safe with holes which I have drawn all at 5mm average.
The upper section shows each valve in the mid position
The lower valve shows 6mm (half of 12mm eccentric movement) from mid position though as Charles says that may need looking into.
The slots between chests are not to any set position.
