- Jan 4, 2011
- 1,441
- 403
What should be used to seal a cylinder liner in a cylinder? I have a liner made from DOM tubing in a steel cylinder. It has holes in the side for intake/exhaust/plug. I put it in using JB Weld and it is leaking around the spark plug hole. I am sure that when it is inserted it scrapes off most of the JB Weld. It is a rather tight fit in the cylinder. It is not a press fit but required some tapping to get it in place. Something like epoxy would probably flow better but that probably would not take the heat. The alternative is to remake it in one piece.
