Ford's Quadricycle Engine
Weirsdale, Florida
While I was waiting on the helical gears to arrive for another project I came across this on the net.
Having already built Ford's Kitchen Sink engine I recognized several similarities in this design. He used plumbing fittings for the intake valves but now he had proper exhaust valves.
The water cooling was new and was thought to have been borrowed from the Carl Benz engine.
He had a buzz coil ignition system that was fired off a brass strip that was attached to the one and only rocker arm. He also had a trip lever that was said to be actuated when the piston was at top dead center but there is no information on this devise that sticks out the side of each cylinder.
It is a two cylinder design with the pistons attached to the flywheel in such a way that both pistons move together similar to a single throw crankshaft.
Since there were no counter weights on the rod throws the engine would have had a large amount of vibration.
A single rocker arm operated both exhaust valves with a single push-pull rod from the timing gear.
Bore was reported at 2.56 and the stroke was 5.98 inches.
There are several variations of the engine but none are the original through out as seen from old videos of Ford himself driving. I ma sure Ford made improvements to the engine also.
There is a lot more to be said and I won't be reproducing the engine but rather building a version of the engine of my own design.
I started with a 2" aluminum bar for the cylinders.
Over to the lathe for the first end.
Flip it around for the other end.
The two cylinders before cutting them apart. Doing it this way I only wasted 3/4" of material.
Thanks for looking
Ray
I cut the cylinders apart and bored the inside for 0.800 pistons.
I usually use cast iron liners but not for this engine. We'll see how that works out.
This piece of channel iron was calling to me from the steel bin.
It said it would make a nice mounting plate for the cylinders.
I just had to remove the bits that were not needed.
Another dodgy setup but the result was a difference of 0.027 from top to bottom. I can live with that.
The result so far.
Thanks for looking
Ray
Thanks for looking
Ray
Like you, I built the kitchen sink engine () and looked at the Quadracycle as a potential future project, not as a model, but as a full scale repro.
I thought it’d be fun to use in parades and stuff, and as a way to take my hobby up a notch!
I haven’t jumped into that project yet, bug I’m sure going to watch what you get done.
Looks like a fun bit of work, thanks Ray!
John W
FYI:
There was a member on this forum: vascon2196. He was here from 2009 through May 2020 and he and his students were working on a full replica of the quadricycle. It was quite a project and I believe they ended up with a running vehicle.
He is still listed as a member. I am not sure what happened to him as I really was looking forward to more from him.
The posts are still available on search, but I have not been able to quickly find a good starting point to refer to.
You can probably find more information by reading some of his work.
Maybe someone else can add more information to follow this post.
--ShopShoe
I have seen his and several other's builds of this engine. There is some good information on the net it is just a little hard to find.
I drilled and tapped the holes for the spark plugs (1/4x32) and the intake valves (5/16x24).
On this engine the spark plugs are toward the inside and the intake valves are toward the outside. That will give me more options for the intake runners later.
Next on to the water cooling jacket.
This 2 1/2" aluminum tubing should work for that.
I machined it like I did for the cylinders all in one long piece and then cut in two afterwards. That way I only wasted about 3/4" of material and still had a full grip in the jaws.
Cut apart
Next will be the end spacers for the jackets.
Thanks for looking
Ray
This was the easiest crankshaft I have ever made. Just a straight piece of 12mm drill rod 4" long with a 1/8" key slot.
I only need the keys on the outer ends for the bell cranks but I just went all the way across with the slot.
Shaft and the main bearings.
I made these main bearing stands from 1/2" thick aluminum. I wanted them that thick to give more side to side support.
The one with the tab sticking up is where the driven cam gear will go.
Also cut out a couple of bearing caps.
Thanks for looking
Ray
I trued up the flywheel and cut a 5 degree taper for the center hole.
Also made an aluminum bushing without changing the compound setting insuring a nice taper fit.
Drilled and tapped the bushing and cut a slot down the middle.
Here it is just sitting on the rails not fastened down.
There isn't much room on the timing gear side. I may have to get creative with the push/pull rod.
Next will be the crank arms and then I will know for sure if I figured everything out correctly.
You never know what might crop up when you build with "That looks about right" plans.
Thanks for looking.
Ray
I decided it was time to make some timing gears as this area is going to be a tight fit and better to fix any problems now.
Drive gear installed.
This is the driven gear but I am not at all happy with how it is attached to the side housing. I will change that over to some ball bearings when they come in.
Thanks for looking
Ray
I turned out the blanks for the crank arms and cut the key ways with the blanks clamped together so they would be clocked the same.
A couple of pictures of them installed on the engine.
Everything is lining up as it should so the time has come to pretty things up.
I painted the base black.
I also made the fitting for the push/ pull rod and checked for fit.
I actually have a 0.040 gap between it and the flywheel.
Will wonders never cease!
Thanks for looking
Ray
You could be right Steamchick.
Pistons and brass piston end connectors.
The brass connectors still need to be sculpted some.
The parts for the connecting rods two shoulder bolts, brass rods, connectors, and pistons.
Connecting rods installed.
Starting to look better with more color now.
Thanks for looking
Ray
Hi Ray,
Since you are not adverse to use of aluminium, I had guessed the conrods would be Aluminium... to reduce the "flying masses" that inevitably produce vibration.
Of course, scaling the engine from the original, the compressive forces are reduced by the square of the scale of pistons (1/4 scale = 1/16th force) but as stiffness is based on the cube of diameter, 1/4 scale means 1/64th stiffness - which is the most important criteria for a con-rod. (The stiffness in compression resists the buckling). So a 1/4 scale equivalent stiffness rod may need to be 4 x larger CSA than a "simple" scaling would give. - or twice diameter of the "Linear scale". I.E. a 1/4 scale rod of comparable stiffness would be 1/4 x 2 x the original diameter. Sometimes this means the rods look thicker on models than true linear scaling would give.
Unfortunately, I can't see the "original diameter" of conrods in this photo?
Maybe these show the Con-rod better?
(By The original uploader was DougW at English Wikipedia. - Transferred from en.wikipedia to Commons., Attribution, https://commons.wikimedia.org/w/index.php?curid=2897972)
But even an original steel rod could be used as the basis to re-designing a scale model rod in Aluminium of comparable stiffness, that would not look out-of-place on your model? - And it would be another bit of "shiny metal" of the same colour as the cylinders, thus complimenting your aesthetic design of "shiny versus black"?
But you are happy with that "thickish" brass, so an aluminium version (nicely polished) would not be likely to look out-of-place, I guess? But then it should be larger again because of the Compressive strength converting from steel to aluminium, which means perhaps an extra >2 times CSA is required, but "1 1/2" x diameter is an adequate rule here: (It depends on shape, off-set loads causing bending, grades of steel and aluminium considered, etc. so is a bit complicated! - But for most models, the "1 1/2" x rule is practical? - And who runs models at full load? If it fails, just try Stainless steel?).
(The whole subject for Slender struts in compression is a bit more complex, and considering modern engine con-rods come as steel or aluminium in an "H"-section to maximise stiffness and minimise mass, the following gives a clue as to how complex this becomes: https://www.steelforlifebluebook.co.uk/explanatory-notes/bs5950/compression-tables/
Look at the discussion on slender sections of steel - (ii) For class 4 slender cross-sections:
I am not criticising your brass rod, just offering an alternative idea...
Another odd comment (That I may have misunderstood?) is that you mention the pistons running in Tandem, so masses act like a bigger single cylinder engine. Is that because the valve gear is a single valve actuation, or something? I would have thought that the esteemed Mt Ford would have used a 90 degree off-set on the crank - or 180degree? - if he was following designs from similar configured steam engines? But of course this necessitates double the valve gear actuation. So I can understand it being like a "split single" engine for that reason. Yet in that case making a larger single cylinder engine would have been more sensible IMHO? So do you know more of the logic behind the design? - Or have I misunderstood all this anyway?
Keep up the good work!
Although there is only a single push rod the valve gear is on a rocker so although the pistons move together alternate cylinders fire.
Going too thick with a conrod usually starts to cause problems with it touching the end of the cylinder. You can see it in that B&W photo where it is very close not lelped by the throwback to steam engine design where there is almost a trunk guide. Some had balance weights in the flywheel to reduce the bounce.
