Upshur gears
Harglo
woodbine MD
Upshur Plans call for 20 degree PD gear cutters.
I have the correct cutters, but are for 14.5 degree ptich.
Can I get by with the same gear center distance for an ok mesh, or if not, how much change would I have to due in what direction?
There are programs online where you can plug in the information, and it will give you specific gear data for a given size/cutter/etc.
I have substituted different gear sets that have different tooth counts, but the same tooth ratio (2:1), and the same center-to-center distance.
The gear experts will have to chime in here, but I suspect you could substitute gears and make it work.
Many thanks yes em sure will get other info.
Harvey
I would say, you are good to go as long as you keep center distance and ratio. (pressure angle does not change center distance)
I used 0.5 module gears and did a profile shift. (gears run smooth)
e.g. 40/20 48DP has 0.625" Center distance and 42/21 Module 0.5 has 0.6201" center distance. Leaves only a small difference.
https://evolventdesign.com/pages/center-distance-calc
Greetings Timo
Greetings Timo
Thanks Timo. Stamped on the cutters for this particular set besides the angle an range of teeth is .045 is that the depth of the cut?
Harvey
Harvey
I am a "metric Person" and not Expert. So I do not know. If I calculate 25.4 mm *0.045 = 1.143 mm it seems at least plausible. (assuming 48 DP is what you have there.)
Addendum would be 1x and dedendum 1.16 x the module. I usually go to 1.25 x module for dedendum, so that would be a little deeper. I would test cut a set with 0.045" and see how the center distance "feels", then adjust depth if required.
Good luck.
p.s.
Some advocate a larger Dedendum for the smaller gear sizes of 1.4 so your 0.045" falls between the two.
https://www.hpcgears.com/pdf_c33/27.48-27.60.pdf
On a model I tend to cut the gears and then use them to set the final ctr distance on the engine with a slip of paper between to allow a little backlash. So you could position the crankshaft holes as drawing and then "depth" the camshaft position to suit
    1.2 MB
    657 KB
Short answer, changing the pressure angle of a gear does not change the pitch diameter.
