Taking it up a step---
Guys
Several of you have mentioned that when turned off the Vernier remembers the last reading and this is a battery drain. Although it is very difficult to check, the battery drain should be very small (nanoA) and is no issue. However cheaper verniers are not well designed and have a larger drain. If you can afford to, stay with Mitutoyo.
Mike
I have been using Mitutoyo at work. With cheapo digitals, they all turn off automatically when not used often enough--not so with the Mitutoyos. they have to be manually turned off. I'm wondering if Mitutoyo users find this with their stuff.
I use a trad vernier at work. It's a PT job in a university machine shop, and none of the students will nick my callipers as they can't read them. Might not stop them borrowing them to open a paint tin, or perhaps mistaking them for a small old-style adjustable spanner, of course. :)
(Did I tell the one on here about the prospective technician who was asked to use a 0-1 mic to measure the dia of a bar? She found the point where it touched and then did it up another turn just in case (and put it out, permanently). They employed her.)
I had someone try to use one as a hammer. Did he ever get an earful.
I've got several battery operated Mitutoyo Verners and micrometres. The Mitutoyo Verners do not turn off. My cheapo Vernier does switch off BUT if you move the carriage it springs to life thus showing that the sensing circuit remains live. The Mitutoyo micrometre displays automatically switch off but again the sensing circuit remains active.
I don't find any of this to be an issue. It is important to use silver oxide batteries (357/303) and not the cheaper alkaline type.
I my view the convenience of digital measuring far out weighs the need for batteries.
I think this thread has lost its way!!!!
Not really. Brian bot some new measuring tools..This is still on thread
My Mitutoyo occasionally turns itself on. The battery has lasted a long time though.
I forgot to turn one off--nono, someone in another class did not turn one off, it was on all nite. Didn't turn off (Mitutuoy or a knock off)
The Mitutoyos at work, do not turn off automatically. The the particular model I linked the instruction to does turn off! There are different models around. Two buttons .. three buttons.
