Westbury 'Seagull'
UK, Warwickshire
Hello people. This is my first post in this neck of the woods. I live in the UK, West Midlands area. I have been doing model engineering for many years, but am currently tackling my first petrol engine.
It's a Westbury designed 10cc twin side-valve job, castings from Hemingway Kits 1.
You can see my progress (not very up-to-date atm, sorry) here: 2.
The latest problem I have with the design is the cam profile. As designed, the tappets are too small in diameter for
the cams, inlet in particular. As shown by plugging the dimensions into this brilliant resource 3, for a brief part of the motion, the cam is in contact with the edge of the tappet face, which seems unlikely to be good for either, or for noise (quiet is one of my criteria of success). Design dimensions are the same as the 'Seal': Base circle radius: 11/64", flank radius: 9/16", lift: 5/64" opening angle: 120°. I probably can make the tappets bigger, but ... any advice?
(1) http://www.hemingwaykits.com
(2) http://www.charleslamont.me.uk/Seagull
(3) http://modelenginenews.org/design/CamTable.php
Well you have 3 options
(1) Make a larger diameter lifter. Great if you have room.
(2) Reduce the lift of the lobe. This will change the shape of the lobe and less diameter will be needed.
(3) Make lifters with a curved surface. If the surface of the lifter that contacts the lobe has a ball end or even any kind of radius you can run a smaller diameter.
If I think of anything else I'll get back here but thats all i have right now.
Hi Charles, very clear construction diary. How come everything looks so clean? I can tell this is going to be a very well made model by the time it is complete. Any ideas what you will use it for yet?
Also, where in the west midlands are you??
Rob.
Thanks. After further exploration, there is also the possibility of a larger cam angle, allowing a 'softer' cam.
I have decided I will probably increase the tappets to 9/32", which I can just get in, even with a bush.
Thanks, Rob
Does it? I clean parts before taking pics, but try to leave a bit of swarf around when showing setups.
Thanks again. No - no idea. I will need some kind of load to try it against, though.
Shropshire
In theory you can’t lap straight involute gears because they mesh with a rolling action, therefore there is no relative movement between teeth for lapping to take place.
In practice if the gears are mounted so that one can move from side to side you can sometimes improve things. With an idler setup like the seagull you would need to lap all three gears at once (moving the idler from side to side) so unless they really need it I wouldn’t bother.
Les
One of many jobs remaining on the Seagull is a silencer (US Muffler). I have an idea what I want it to look like externally, but have little clue as to what to put inside it.
I am thinking of a drum 3/4" diameter and about 1-1/2" long, with a tangential or radial entry at one end and an axial exit at the other, both in 5/16" OD tube, all brass.
I want maximum noise reduction for minimum resistance, and would prefer to avoid a stuffing that will get clogged up, unless that is the only good way, even though it would probably be arranged for easy dismantling.
Ideas?
In typical RC 2-stroke exhaust systems, its common to see a silencing section to the back end of tuned pipes for noise reduction & simultaneously minimize resultant back pressure. I have seen
- series of baffled chambers with offsetting entry/exit passage connector pipes or orfices
- perforated diffuser tubes like pic (kind of like a firearm principle I imagine).
- simple deflector plates in canister type mufflers (maybe a coarse version of above?)
Disregard the tuning aspect, but just mentioning the similarity of noise reduction chunk. RC fuel has oil added, so exhaust contains gunk & similarly favors an all-metal configuration vs. noise abatement stuffing as you call it.
See after the small hole for air under idling position must be open to learn out where position the trottle is closed. (Mixture airscrew with other word to lean/rich the fuel under idling).
Fuel tank (brass): soft or silver solder?
I would opt for silver solder on the basis of the much higher melting point. If you ever had an engine fire it might get hot enough to melt the soft solder making it a much bigger problem to deal with.
It would probably never melt silver solder.
soft solder will be more than fine. All my tanks are done with soft solder. Exhaust pipes are the only think I silver solder. If you ever have a fire hot enough to melt the solder on the tank chances are most of your garage will be gone before the tank un-solders and opens up.
In my trade in the UK we are not allowed to soft solder copper fuel lines in case they breach in the event of a fire.
I therefore would apply the same logic to a storage tank.
I have had to replace water filled pipe work that had melted joints following a fire so I know it can melt.
Better safe than sorry in my book.
Soft solder will be fine.
If an engine fire rages long enough is hot enough to melt the soft solder, chances are a silver soldered tank will fracture and spray fuel everywhere anyhow.
