waterloo traction engine .29 scale
sawyer massey
We started a groop build a waterloo 25 HP side mount
The reason for the scale is a 10 inch pipe works out to boiler diameter so scaling the rest from there IMG_20190825_181113.jpg IMG_20191124_133043.jpg
No I made them the old way out of wood
I have 5 of every think to cast its a group build
Thanks for asking
Governor pattern and partly machined casting and cylinder head
Think I'm getting better at this the last crank and govenor
Also the steam chest cover I burnt the sand of first way softer irion
We are working from a friends full-size engine
5 of us are building them
The drawings I am making up as well as the patterns
As for the casting it is iron
We use an a10 or an a 20 crucible depending on what we are going to poor
I use green sand and spay it with graphite and alcohol
Helps with the chill and the finish of the casting
The foundry is fire on oil
This is as far as I am right now
