vederstein Must do dumb things.... Joined Feb 26, 2011 Messages 921 Reaction score 746 Oct 11, 2022 #1 This is a continuation of my Dancer's Engine. Because the previous Plans thread was too long, here's a new thread with just the plans. First couple of posts the PDF drawings: Attachments Assembly - Dancers Engine on Base.pdf 901.6 KB · Views: 17 Assembly - Dancers Engine.pdf 829.7 KB · Views: 17
vederstein Must do dumb things.... Joined Feb 26, 2011 Messages 921 Reaction score 746 Oct 11, 2022 #2 More pdfs... Attachments Assy - Base.pdf 122.7 KB · Views: 12 Assy - Camshaft.pdf 112.5 KB · Views: 6 Assy - Crank Connecting Rod.pdf 119.1 KB · Views: 15 Assy - Crankshaft.pdf 131.1 KB · Views: 9 Assy - Cross Slide.pdf 107.2 KB · Views: 6 Assy - Cylinder 01.pdf 112.8 KB · Views: 14 Assy - Cylinder 02.pdf 114.4 KB · Views: 4 Assy - Piston Rod Link.pdf 93.3 KB · Views: 10 Assy - Piston.pdf 113.7 KB · Views: 19 Assy - Stand.pdf 111.9 KB · Views: 7
vederstein Must do dumb things.... Joined Feb 26, 2011 Messages 921 Reaction score 746 Oct 11, 2022 #3 ...And even more pdfs... Attachments Assy - Upper Plate.pdf 123.7 KB · Views: 8 Assy - Valve.pdf 110 KB · Views: 6 Assy - Walking Beam.pdf 107.8 KB · Views: 17 Base Plate.pdf 102.2 KB · Views: 25 Beam Shaft, Main.pdf 99.8 KB · Views: 17 Bearing Block, Cam Shaft.pdf 102.5 KB · Views: 14 Bearing Block, Crank Shaft.pdf 102.1 KB · Views: 9 Cylinder 01.pdf 115.8 KB · Views: 6 Cylinder 02.pdf 112.7 KB · Views: 7 Cylinder Head Seal Cap.pdf 100.9 KB · Views: 6
vederstein Must do dumb things.... Joined Feb 26, 2011 Messages 921 Reaction score 746 Oct 11, 2022 #4 Ok, this is the last pdf post. Attachments Gear, Bevel, Cam Shaft.pdf 120.3 KB · Views: 15 Gear, Bevel, Crank Shaft.pdf 121.4 KB · Views: 20 Head Gasket.pdf 11.8 KB · Views: 22 Link - Piston Rod.pdf 96.2 KB · Views: 10 Spacer, Main Bearing.pdf 110.3 KB · Views: 10 Upper Plate.pdf 97.3 KB · Views: 8 Valve Cage.pdf 103.9 KB · Views: 13 Walking Beam.pdf 104.4 KB · Views: 15 Wooden Base.pdf 226.3 KB · Views: 7
vederstein Must do dumb things.... Joined Feb 26, 2011 Messages 921 Reaction score 746 Oct 11, 2022 #5 And finally the solid model (step format, zipped). Enjoy the design. ...Ved. Attachments Dancers Engine.zip 716.1 KB · Views: 5
