vederstein
Must do dumb things....
- Feb 26, 2011
- 918
- 745
In the Plans section, you'll find some musings on my version of a water pumping steam engine located at the London Museum of Water and Steam (a.k.a. the Kew Bridge Steam Museum).
Being that this engine has a some components where the techniques are new me, I felt I'd share my learning experiences. I don't intend on documenting every part, just those components that have difficult or weird setups.
First off is the walking beam.
It started as a piece of 1/4 x 1-3/4" barstock. I drilled in the pivot points to be a close fit for the 1/4-20 bolts.
Then I transferred the blank to my Mini-Mill that I put a CNC conversion on years ago. As many know, a Mini-Mill is well, mini. Therefore I could only profile and pocket the walking beam in halves. I did the left side, then rotated the part and machined the right. Then I flipped the part and pocketed the opposite side. The close fitting holes allowed my to break down and reassemble the setup without losing too much positional accuracy. It's not that important though. Other than the location/size of the holes, the actual profile and the pockets are more for looks than anything else.
After the CNC milling, I transferred the (now looking like a) walking beam, to manual mill. Using it like a drill press, I drilled out and reamed the part. Then, after a bit of deburring, the part is complete. Then make a second...
Being that my Mini-Mill Y-axis motor had a coupling failure, these two parts took all day to make. That's enough for one day.
...Ved.
...Ved.
