johnlaudano
- Jan 17, 2011
- 95
- 115
I'm working on a V4 engine I designed. The crankcase is a weldment but the rest is made from solid on manual machines.
It will be fueled by gasoline or propane but I'm not sure which way to go. If it runs well it will likely power a boat of about six feet long.
I'm not a purist and my machines aren't very accurate so i bought pistons, rings, and valves.
The cylinder liners are 12L14. The cams are A2 steel and will be fastened to the shaft with 680 Loctite and pins.
The rest of you on this forum have been great inspiration and I see lots of fascinating projects and workmanship.
