- Feb 26, 2020
- 582
- 366
Hello,
I am getting side tracked all the time . Reading this in a gear cutting thread. .....
Results in fixing my poor mans slotting head. Replaced the not very successful dove tail with a 2nd hand linear rail.
Is it wasted time? Anyway sort of a fun project. As drive it has a 10:1 used gear motor.
Now I have to remove the spindle head from the milling machine in order to mount the heavy thing. A better change over solution would be clever.
I cut some gear rack out of 6 mm brass stock. It behaves with the diy gear (right) and the plastic gear from scrapped printer.
How to align a hole properly relative to the cutter is the challenge now. If anyone has a good tip it would be nice.
Hi All,
Now just the engine, still need to do the 1/16" key way in the drive gear, then heat treat the gears.
Andrew
