peterl95124
- Feb 22, 2020
- 430
- 261
Minh-Thanh, nice choice of engine to model !!!
I have built a working gasoline + spark version of the Hansen Diesel, as a precursor to an actual diesel injection version (like Hansen's its all built out of silver-brazed together sheet steel), if you're curious look for "my hansen diesel" on youtube, "mostlyIC" is my current channel name.
but on to my point, I researched making my own helical gears (Hansen did) and never found a method that I liked (the best IMHO is George Fellows' design, George Britnell has plans for it, if you insist on home made), so I bought gears, even that took some searching, finally found 45-deg helical gears in 48-DP with teeth of 15, 20 and 20, 30, from rpcgears.com in UK ===> so I designed the engine around those gears <===
Also, it looks like you're using a worm gear up top, that means the vertical shaft is spinning really fast, that means the gears at the bottom (crankshaft) have to be step-up rather than step-down, but if you experiment with skewed helical gears you'll find this isn't practical, they will have too much friction and won't move without undue force or simply won't move at all. that's why my choice of gear teeth are reduction gears at both the top and the bottom, and they run very smoothly without any unnecessary friction.
anyway, I'm really looking forward to seeing how you design and implement fuel pump and injector for your new engine, I might want to copy to avoid doing my own time consuming experimentation (getting old and lazy !!!)
