Richard Hed
- Nov 23, 2018
- 2,385
- 618
The photo shows two belts. Which one is slipping? When you got the lathe, did YOU install the belts or did they come pre-installed?
It spindle belt slips on center pulley on low speed.The photo shows two belts. Which one is slipping? When you got the lathe, did YOU install the belts or did they come pre-installed?
The is on the pulley with little v in the groves.Are ;you sure that belt is installed the right side out? Looks to me like it is not but I cannot tell by the photo
Found a belt tension guide...
https://simplybearings.co.uk/shop/files/chal_belt_tensioner_p168-169.pdfBut I don't think this covers Polly-Vee belts.
For tensioning Poly-Vee belts, it is relatively easy to measure tension by a calculation from the frequency of the note generated from the belt in tension. Load this App to your phone.
https://www.hutchinsontransmission.com/resource-center/apps/easy-tensionMeasure the centre to centre distance of the span, pulley diameters "mid-depth" of the grooves.
Or measure the belt-span from pulley to pulley at the tangential contact points.
With the data I think the app will give you a frequency of the note you should have when you Twang the belt. - Tap it with a spanner. It is "what we did" on the car production line I.E. tap the belt while using the frequency meter, then tension the belt until the correct frequency. Rotate for a full belt rotation, re-check/adjust. Doing 200 cars a shift, the lads knew exactly what tension to apply so when rotated it was correct.... But doing 1 belt you need the rotation and re-adjust, until it is correct. That was back in 1986~92...
But maybe the App is easier?
OkFit a decent quality belt...looks like the belt came from mainland China with the rest of it.
or...back off on the cuts (which amount you do not say)...it's a mini lathe afterall.
This my first time with mini lathes.I haven't used that lathe yet, but I have used another machine with a similar belt before. There is a reasonable way to prevent it from slipping: find the cutting speed and how much material should be cut. I think, with small machines, it needs cutting tools that are as sharp as possible
H Dave .This my first time with mini lathes.
Before this lathe I some lathes with up to 30 hp.
This is a big change for me.
The chuck it self is flywheel it weight was over a ton.H Dave .
That is a big change .
With small machines, the torque is not much, so try with the diameter of the workpiece you usually use (flywheel) and process with steel workpiece then you will know more. Using a sharp tool or sharpen tools to sharpness , with small machines is my best choice .
Use it and find the right machining method for that lathe.
I could be a little greedy with my cuts.Dave, you asked, "So what type cut can make with mini lathe ?" - My answer is that it really depends on how well the lathe is supported against twist - as you mention for bigger motors/higher torque - as the bed of a "Modelling" lathe is not strong enough on its own to withstand much torque. Even when the bed is well supported, the cross-slides etc, cannot withstand the torque beyond the torque your motor will stall at. So use your experience and "don't let the cutting load drop the speed", is the simplest basic rule.
On brass less than 1/2inch I am using 0.020in cuts with a careful feed, or 0.010in cuts at a faster feed rate. But usually stay within 0.010in cuts as on small model parts there is hardly any real great volume of metal to remove, and time is NOT a problem to me. And I enjoy the time cutting metal. A lot of accurate cuts is much better than 1 heavier cut that loses accuracy by distorting the lathe! - Many people (usually with heavier ex-production machines) tell me they bigger cuts easily. "Well done" to them, but I don't. I learned (as a child) on a 3 in swing lathe driven by a foot treadle, from a Singer Sewing Machine. So small cuts were the order of the day, as my 8 year old legs could not develop much Torque! My current lathe, same size as yours, is the biggest I have owned (my 6th) and fills my work-space. If I want more lathe I can use the ex-industrial lathes at my Model Engineering club. They have a Myford ML7 - no better than mine) and a large 10in swing industrial lathe with 5H.P. 3-phase motor, and something a bit between. But I have never needed them. Fine cuts and patience will make anything that will fit in the lathe. You have the experience of cutting speeds and feeds, and knowledge to know when a cut is too big. - You can hear the motor, feel the vibration/cut/feed, and see the lathe "twist", so you'll know when you are dong too much.
No hard and fast rules here though...
I try turning O1 tool steel today make a carriage lock .Dave, you asked, "So what type cut can make with mini lathe ?" - My answer is that it really depends on how well the lathe is supported against twist - as you mention for bigger motors/higher torque - as the bed of a "Modelling" lathe is not strong enough on its own to withstand much torque. Even when the bed is well supported, the cross-slides etc, cannot withstand the torque beyond the torque your motor will stall at. So use your experience and "don't let the cutting load drop the speed", is the simplest basic rule.
Here is the install Aloris.Hi Dave, what we are all looking forward to are some pictures - to inspire us to improve our lathes..?
Ta,
Here good photo of turning a square shaft in a steady rest.Hi Dave, what we are all looking forward to are some pictures - to inspire us to improve our lathes..?
Ta,
More photosHi Dave, what we are all looking forward to are some pictures - to inspire us to improve our lathes..?
Ta,
