- Jul 16, 2007
- 2,993
- 1,061
This thread is to answer a question about split bearing inserts for connecting rods but will cover the making of the rods and inserts.
These rods were made for my flathead V-8 engine. They were made from 4140 steel. I could have made them from 1144 but would have had to cut round stock into a rectangular section.
I cut the stock to thickness, width and length. The length was left long to cut the cap material off and then mill to size. The stock was stamped with 1/16 number stamps to match the caps and rods. The stock was drilled and tapped and clearance drilled taking into account the metal to be removed by cutting the cap of. I also drilled for the pin hole which will located the bearing insert.
