Lanz tractor
Sorry not have had time to follow the conversation, I have now too many other projects going on.
I am breaking my head trying to figure the valve operation.
Is it operated by the cam on the crankshaft? If so what is the part that rides on the cam?
From the assembly it may appear that there is a linkage from the flywheel rim to the bracket/shaft/lever contraption on top of the cylinder. In that case there is no hole for a screw on the flywheel.
Has anyone figured that out? Appreciate help.
This is as far as I got
To people that have built a Lanz per plans.
Does the transmission parts drawings and assembly makes any sense? Does it work?
I can't figure how it all works, Forward-Idle-Reverse
Thanks
hello
yes it works, there is good forward and reverse gear, I did not control the clutch on mine
Thank you so much GG89220, the pictures are awesome and very useful.
I suppose the only way to figure it out is to build all the parts and see how the can fit.
I have done something similar in a virtual way by redrawing them and playing like when you move "paper" furniture's on a "paper" room.
The tranny is beginning to come together.
Now another question. How is the wick lighted? There seems to be no access.
How is the engine shroud fastened to the chassis?
Thanks
hello
slide the top
