k 27 wheels
Thanks Wizard .Not as many as it my seam .The brass flat stock and some of the bar stock is the only things I have had to buy that are really costly ,with the new traffs it has gone why up. . By casting the larger brass things I have saved alot.I have a friend who is a plumber so I get all his old brass fixtures . I had to build my furance and aquire some tools .But I have done very well at keeping the matrial cost down .I get alot of metal at a scrape yard also.Thanks Dale
I made some changes to these parts to be more like the real K27 .Just need to make some bolts of the right desi
Well I have learned to use Fusion 360 .Here are a few of the parts I have made .This is just 2D Now the next thing will be 3D .Also here are some pic. of the ash pan.
Nice going Dale on learning Fusion.
It's getting hard to leave my Wife.I want to get together also. I'm working on the poly wag. It's under finished projects poly wog.
Here is some pictures of what I have done on the cab.The top has not been cut to size. Sure is nice to finely know how to use my CNC!
Here is some more of the work that I have got done .Would much work on the bigger peices.
Well, I fired my loco... Good and bad, everything worked good. The cyl. leaked a lot though, through the solder joints, I think I will put a sleave in the passages from the valves to the cyl. All in all not to bad.More work for this winter!
Well, I have finely got some time to work in the shop. The leaks in the cyl. are not as bad as I thought. Here are some pictures of my PSI gauge. Making the bourdon tube was a real chore. The glass is a watch crystal.CH][/ATTACH]
Nice job Dale. I'm still here playing a little in the shop. keep up the good work of a master machinist.
I take the photos as a functional pressure gage, what kind of a movement did you put in it? That would be a neat concept to share!
