Duesenberg Straight 4, quarter scale
its the little things that take so much time...
here are the distributor and oil pump, still works in progress
(and there's a water pump part currently clamped to my mill,
which is taking up lots of mental energy to design)
a small amount of progress on the water pump (have mostly been working on other projects)
some (fun for me!) rotary table work was involved, plus lots of filing afterwards
some machining operations on the rotary table for the water pump scroll
first is approximating the scroll height as a staircase
second is using a 45-degree end mill to approximate the tubular roundness of the scroll
speaking of "small parts", I recently ground the pair of cam shafts
(am very pleased with the results I got switching to a CBN wheel
but not sure how to dress the wheel once that is needed)
perfection is the enemy of git-er-done, this doesn't look great, but will be functional and well hidden inside the water pump
mostly machined on a tilting rotary indexer, with a little bit of dremel work afterward
the entry and exit blade angles are wrong for a water pump, but won't make much difference for an engine that only gets run for short periods of time for demonstrations (a similar water pump on my Merlin V-12 blew a plastic hose off its fitting, so "good enough for government work" !)
water pump housing needs inlet pipe
if you have a mill vise you're at the start of a long journey of collecting necessary clamping fixtures and devices :) !!!
